NetDBMgr.InitDrvrFail
Description
netDbMgr failed to initialize a database driver. Driver initialization failures result in netDbMgr failing to connect to remote databases of the specified type. This is not expected and is indicative of a serious problem.
Remedy
Try restarting netDbMgr using "restart process netDbMgr" command. If the issue persists, on systems with backup nodes try failing over to the backup. Standalone systems may require a reboot to correct the problem.
Severity
Error
Message Text
Network Database Driver: %name% initialization failed with error: %error%)
Message Parameters
Name Type
name String
error String
